Posted by Janicholson on February 27, 2011 at 17:08:14 from (67.72.98.45):
In Reply to: H trottle posted by bmagee on February 27, 2011 at 15:44:20:
The rod from the hand throttle has the governor control equalizer (U shaped metal) that slips on first, then one spring then the governor control pivot, then the other spring, then the last flange of the equalizer. The nut holds the equalizer in position, and is tightened to do so. The springs keep the sliding pivot centered. If the springs are week, putting washers on either side of them can center the pivot. The linkage should pull the governor rod to full limit of travel when in the rear notch of the hand lever, and all the way to the idle position when forward. Adjustment of this is usually not needed. if it is not going full travel when operated at the hand lever, washers could be used to move the pivot between the springs such that it does. In all cases the pivot should be between two springs. See diagram in caseih.com search for parts. Jim
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
