Farmall Tractors Discussion Board
Re: Farmall A crank pulley
Posted by Doug on January 03, 1999 at 17:42:19:
In Reply to: Farmall A crank pulley posted by Brian on January 03, 1999 at 09:00:36:
Brian, I had the same problem with the pulley on a cub. I used a 3 way puller, tighten it down but not till the vains stick out on your neck or you'll have pieces. Put a fair amount of pressure on it then start tapping the end of the bolt on the puller. Do that for a few taps and put a little more pressure on it, and tap it again. Someone on this board told me to do that and it worked. it takes a little while but I think that will work. good luck. Doug
Post a Followup
: Re: Re: Farmall A crank pulley
