Re: 300 Farmal discharging
Posted by old on February 28, 2011 at 09:12:46 from (4.245.13.31):
In Reply to: 300 Farmal discharging posted by Shawn MN on February 28, 2011 at 09:01:38:
A lot more info is needed for us to be able you help you help your self. If it has a mag which I do not believe the 300 had then it doesn't even use battery power. Things like does it have a generator or an alternator and is it 6 or 12 volts. Things like that are needed for us to be able to help you.
Now if I where to guess and figuring it is 6 volt with a genny I would stay an bad or sticking V.R.
