Re: Re: hyd pump capacity
Posted by Jim on July 17, 2000 at 20:46:03 from (199.240.128.68):
In Reply to: Re: hyd pump capacity posted by twopop on July 17, 2000 at 12:50:20:
The smallest pump for the rear outlets is 12gal the front pump on the MCV valve is 9 gal pump.
If someone wants you can go as high as 26 gal on the rear outlets.
Post A Followup
: Re: Re: Re: hyd pump capacity
