Re: Cub Cadet 125
Posted by dhermesc on February 28, 2011 at 11:31:52 from (24.248.193.103):
In Reply to: Cub Cadet 125 posted by 53DC on February 28, 2011 at 10:06:09:
The slop in the steering is common, between the worn cam follower and the tie rod ends it can be fixed. The cam follower is almost $30 and the tie rod ends are about $8 to $10 each. The hydro lever probably needs new nylon inserts to tighten it up.
http://www.partstree.com/parts/?lc=Cub+Cadet&mn=125
The 125 is about as good as any other Cub Cadet. The biggest issue I have is that the seat isn't nearly as comfortable as some the older and newer cubs.
If you buy it the first thing I would do is drain the transmission fluid and replace the filter. No telling how long its been in there.
