or too far back. On ours, extreme Draft Light is pretty much "raise," and extreme Draft Heavy has the least affect on lowering. and if you put your posistion lever too far forward into the offset (or the linkage needs adjusting), it will slow the lowering considerably. If you wish to use draft control mode, lower below half-way then put lever at desired draft position after implement is in ground. There are some other tricks and learned skills to operating these and using to full advantage of system, all covered in the owners manual. make sure you have the quadrant guide and stop screw (and the quadrant piece itself), they make operation on the go much easier.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
