Re: Cub Value
Posted by CraigChristian on February 28, 2011 at 14:41:12 from (69.58.128.90):
In Reply to: Cub Value posted by 45JDB on February 28, 2011 at 10:01:45:
'48 is about the peak year of production in numbers term so there's a bunch out there. Don't get enthralled with paint and decals, it's not a rare Cub by any means. That being said, you may luck out by making sure the tank is clean, pouring in a bit of fresh gas and firing it up (after priming the oil pump first !!) I'd take a crank and see if it's free for starters. I'd also test the radiator and see if the anti freeze afforded enough protection in your area to prevent cracking the block. Probably mice have nested in the air cleaner or in the torque tube - who knows. I'd never pay more than 1200 given the variables involved. Maybe try to find a "Cub guy" in your area who could help you assess condition/value. Good luck - keep us informed. Craig
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
