Re: 350 Utility Power Steering Retrofit Round 2
Posted by JeffL on February 28, 2011 at 15:32:14 from (208.77.0.2):
In Reply to: Re: 350 Utility Power Steering Retrofit Round 2 posted by Janicholson on February 28, 2011 at 15:21:31:
That is great news, thank you so much. can you also tell if manual steering arms were the same part number as the power steering arms?
I am guessing the two arms on the manual system look different from each other because the previous owner thought he was making an improvement after it broke and he welded it back together.
It seems the steering system in general was the weakness of the 350u. I hope I have better luck. i am tempted to beef up the arm ahead of time since the right arm broke on both. I could weld a piece of channel around it.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
