Re: H 12 volt conversion ?
Posted by Faster346 on February 28, 2011 at 17:13:30 from (72.241.201.224):
In Reply to: H 12 volt conversion ? posted by Don Mac on February 28, 2011 at 15:49:43:
Adam Cisewski said: (quoted from post at 17:38:54 02/28/11) If Im buying new would I be better to go with a 1 wire or stick with the 3 wire?
Go to Napa and tell them you want a 3 wire Delco 10si alternator. It will probably cost you 40 or 50 bucks. I have a Delco 10si 3 wire on my H, and a 1 wire on my Super C, and the 1 wire wont ever charge without the tractor being 3/4-Full throttle, and for whatever reason always draws on the battery so I have to disconnect it when not in use. That could be due to the wiring from the previous owner though..not sure. But most diagrams I see are for 3 wires so that's what I prefer.
While you're there tell them you want a Napa part number IC14 12v ignition coil too (11 bucks) so you don't have to wire in a resistor.
This post was edited by Faster346 at 17:15:19 02/28/11.
