That is the same setup that I have, size of compressor and blaster both. It is rather slow and uses a lot of sand. My compressor does not have a 100% duty cycle, but since most of my time is screening the sand while filling the blaster it has time to cool off. A lot slower than the pros, but I don't have to move the equipment and I can do it when I want to. Nearest pro blaster is 30 miles away. As far as priming as soon as it is blasted, I have no need for that. I can let stuff sit inside for months with no rust.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
