Re: actual bore diameter of a 560- 282 diesel without sleeve
Posted by NolanJae on February 28, 2011 at 17:32:33 from (97.127.81.160):
In Reply to: Re: actual bore diameter of a 560- 282 diesel without sleeve posted by Owen Aaland on February 28, 2011 at 14:59:36:
Great info- thanks I just dont have the abilty or equipment to measure poundage on the pressure while I installing sleeves. My biggest question is if I can determine what would give me that type of pressure when I install sleeves via measurements of the block bore size in relation to the O.D. of the sleeve size. What is acceptable. From the info I have gathered the sleeve needs to be aleast somewhat bigger than the bore to get a press fit. How much bigger is too big or too small. is .002-.003 too big or should it be more like .001-.002
