Re: Farmall Cub Locked Wheels Info
Posted by glennster on March 01, 2011 at 04:23:11 from (99.90.9.153):
In Reply to: Farmall Cub Locked Wheels Info posted by Kendog on March 01, 2011 at 04:12:40:
could be a number of things causing the lock up. if you pull the cover, try and center the two shift rods for neutral. could also be ice in the case too. an option to move the tractor without a lot of fooling round is to use a set of skates under the rear tires. we have them on our tow trucks for loading a disabled vehicle where the wheels will not turn. you can build a set with some wood and a couple sheets of smooth steel or tin for a slide surface. here is a link to what skates look like. they work well on hard or soft ground. go jacks are another option, but they need either concrete or blacktop to roll on
