Re: Farmall Cub Locked Wheels Info
Posted by Bob M on March 01, 2011 at 06:45:33 from (67.240.171.41):
In Reply to: Farmall Cub Locked Wheels Info posted by Kendog on March 01, 2011 at 04:12:40:
Hey Ken - If it was stuck back in August the problem's most likely the transmission caught in 2 gears at once.
The Cub transmission is pretty simple inside (same 3 speed transmission is used in the early Cub Cadet garden tractors). Removing the top cover should let you quickly figure it out and pop the offending gears back into neutral.
Also....with all the ice/snow we still have here you should be able to winch the Cub aboard a trailer without difficulty, even with the back end locked up solid. A couple smooth planks with a little wet snow on 'em will slide the rear tires very nicely!
Good luck!
Bob
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
