Re: Thoughts on "originality", NOT a rant on being
Posted by sflem849 on March 01, 2011 at 06:54:04 from (69.197.84.192):
In Reply to: Thoughts on "originality", NOT a rant on being &qu posted by Tom Fleming on March 01, 2011 at 03:13:27:
Where do period appropriate aftermarket parts come into play? I sure don't want to take out my M&W kit. You can't see that, so do I pass? Where does the M&W governer come into play? I don't want to take that off either? How about this? Should it stay or should it go? (After I take the cobbled up bolt and nut/washer setup off)
To me, it doesn't matter what's inside. I will even weld thing up on the inside so you can't see it on the outside or things like that. I do like mine to look original on the outside. You bet your but I put the cast iron seal retainer in my MD when I found one. I didn't want problems from the white metal POS again.
third party image
