Re: Inspecting 400 governor
Posted by Janicholson on March 01, 2011 at 07:04:12 from (199.17.6.194):
In Reply to: Re: Inspecting 400 governor posted by Bugspot on February 28, 2011 at 13:31:25:
Governor is possible, but fuel mix at idle is more likely. The idle mix is adjustable. If it also has some crud in it the nescrew won't do much. Jim
