Re: 282d sleeves -who sells .002 oversized sleeves?
Posted by Janicholson on March 01, 2011 at 07:11:58 from (199.17.6.194):
In Reply to: 282d sleeves -who sells .002 oversized sleeves? posted by NolanJae on March 01, 2011 at 05:50:56:
THe bore can be easily honed to .0045" to light press fit the sleeve. Sunnen straight hone or equal will do it. Make sure the stones are not worn/tapered used too much. 200 grit would be great. This can be done in frame if protection is given to the crank and journals to prevent contamination. Stamping .005+ in the block would be nice. Jim
