Re: Char-Lynn Power Steering on MD - Pics and help needed
Posted by sflem849 on March 01, 2011 at 08:16:03 from (69.197.84.192):
In Reply to: Char-Lynn Power Steering on MD - Pics and help needed posted by sflem849 on February 28, 2011 at 11:04:14:
I guess I would have to call my tractor a working tractor since it isn't a show tractor. :wink: I still want it fairly "correct" wherever correct is.
Does your pump adjustment have a screw that can be tightend to tighten the belt? Mine has a pretty fancy setup for tension making me think it might not be home made.
Do you end up having to make sure the gen and ps pump turn the proper way? Does the whole motor turn backwards or just the hour meter and distributer area go backwards?
