Re: f-20 front wheel wobble
Posted by Ron in Nebr on March 01, 2011 at 11:04:08 from (66.252.114.60):
In Reply to: Re: f-20 front wheel wobble posted by Nebraska Cowman on February 28, 2011 at 04:02:48:
Actually(assuming narrow front) he should be able to run the one "good" tire up on a board and not have to deal with a jack for a quick check. Then spin the suspect wheel and see if it's bent. You should be able to feel a bad wheelbearing that way too. Also grab the top and bottom of the tire and give it a wiggle to further check wheelbearings.
