Re: Intl 434 - broken suction elbow
Posted by Troy Schubert on March 01, 2011 at 18:10:23 from (76.24.64.57):
In Reply to: Re: Intl 434 - funky hydraulic line posted by neblinc on February 04, 2011 at 10:20:22:
third party image
third party image
Hey, Randy -
HA! Finally found my problem last night. Hydraulics have been slow, fluid foamy, and if I operate the loader for longer than 5 mins, I build up so much pressure (foamy fluid) in the reservoir that I start blowing fluid out of the reservoir. Last night I found I have a crack in the elbow on the intake side of my hydraulic pump. It works great as an air injector.
So far having no luck finding a replacement part. I'm thinking of tapping the .75" hole on the intake side of the pump with NPT thread. Then install an adapter of some type to get to 1" intake tubing. I tried local IH dealer with no luck. Might try salvage yards before I start making permanent modifications.
How's your tractor going?
