Re: Farmall 560 with yellow block, carb 534932R91
Posted by bc on March 02, 2011 at 08:40:12 from (69.148.144.242):
In Reply to: Farmall 560 with yellow block, carb 534932R91 posted by David L. Bowers on March 02, 2011 at 05:43:09:
David, I've got a 2606 with a replacement engine. I don't have my stuff handy but your carb number sounds familiar. My carb number didn't show up at the case dealer. It is a 1 3/8" intake throat carb that doesn't show up for any of those models although the IH manual mentions one for a 560. What size throat is yours?
I assume you are looking for a larger float needle and seat as opposed to your main jet. Go to caseih.com and do a search for parts. Start looking for at the gas internationals and farmall from 606, 656, 706 and so on till you can find a bigger needle and seat. Then go to dealer to look for one since they are lost without a part number. Have a few numbers and maybe some fishing line or something to compare the throats of the seats. They are cheap, maybe you can drill one out a little without messing up the seat taper for the needle.
First, I'd do a flow test from your gas line till you have filled up a 5 gallon can. You could have an obstruction in your sediment bowl valve or thereabouts.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
