Posted by LOU from Wi. on March 02, 2011 at 13:09:31 from (174.124.110.80):
In Reply to: Grinding the Gears posted by Enar on March 02, 2011 at 13:03:57:
Most of these older tractors don't have synchro in the transmission, meaning when you start it in neutral they will spin the transmission gears(even though it doesn't go anywhere) so when you get on it and push the clutch in,it will take a little time for the transmission gears to stop moving.That is usually what is going on.Now sometimes the clutch wears down and even though you have the clutch pushed in,it still is turning(slightly) the transmission gears,and when you try to select a gear,it will grind until it slows itself down enough to go into that gear.Just my 2 cents worth.Hope this helps, Regards, Victor
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
