Re: Farmall 560 with yellow block, carb 534932R91
Posted by bc on March 02, 2011 at 13:28:26 from (69.148.144.242):
In Reply to: Farmall 560 with yellow block, carb 534932R91 posted by David L. Bowers on March 02, 2011 at 05:43:09:
7.5 gallons per hour may be problem. I can drain the tank on mine and fill a 5 gallon jug in 5 to 10 minutes depending on if I drain off the 3/8" line coming from the tank or the 1/4" steel line going from the sediment bowl to the carb. Your fuel tank outlet or sediment bowl may be partially rusted up.
I'd remove everything from the tank. Then let us know. Your problem really sounds like a gas flow problem from the tank to the carb and not a needle and seat issue.
As for needle and seats, you just have to do a pars search on caseih.com for model tractors and combines that may have a larger carb. Then take those numbers to the dealer and measure them. They may not stock much which is hit or miss.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
