Posted by Janicholson on March 02, 2011 at 13:41:03 from (199.17.6.194):
In Reply to: Grinding the Gears posted by Enar on March 02, 2011 at 13:03:57:
Beyond the ideas below are two possibilities. The pilot bearing on the snout of the clutch shaft (center of flywheel) can be dry or gummy and cause drag. Most can be lubricated, check the manual. A slightly warped disk can drag on the PP or Flywheel and also cause spinning of the gears. Push in the clutch and count to 10 then shift. If it still grinds, check the level of fluid in the trans. If it is low, or someone put hytran in it rather than the 80-140 oil it should have, will also allow excess gear run on. Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
