Re: Grinding the Gears
Posted by gene bender on March 02, 2011 at 14:23:17 from (67.55.227.7):
In Reply to: Grinding the Gears posted by Enar on March 02, 2011 at 13:03:57:
Probably its the pilot bearing in the crankshaft dry and dirty. There is no way to get any lube to it without splitting. Make sure the trannys lube is up to the level. The level plug is behind the brake rod on the left side. Use 90wt. Mite also want to check the free pedal on the clutch to make sure when pedal is pushed the disc is free. You can lube that bearing from the left side bell housing. You can use a lite to see the zerk.
