Made brackets to mount pump to injection pump timing cover, complete with a tensioner screw. I used a 3.5" pulley and it works great. Also the B belt runs lower in the fan pulley groove where it isn't all worn out.
Diesel engine turns normal, only the distributor has a problem because of extra gear in the chain.
So far the only MD setup I have seen completely under the hood is one similar to yours, but with a separate tank. The guy drove it off the crank with another belt and had to move the fan forward to clear the belt, also trimming the shroud a bit to let the belt pass. He mounted the steering pump directly above the injection pump gear. That had to have been kinda ugly to do as I just examined that tradeoff and it isn't easy because of the way IH water pump is built. I have a picture of it but posting here is so annoying I don't use it.
PS: If you ever have cold starting problems, like when it chuffs and won't catch, drop the air filter cup.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
