Re: Can't decide if I should restore H with wheel weights?
Posted by pete 23 on March 02, 2011 at 16:17:57 from (173.87.146.142):
In Reply to: Can't decide if I should restore H with wheel weights? posted by Yooper Farmall on March 02, 2011 at 13:25:20:
I don't like weights on them. But of course I am a mechanic and always had to take them off or handle the extra weight. I had big husky farmers bring their tractors in loaded with as many as 18 front suitcase weights and little old me had to take them off, (at shop rate of course). Can't even lift one anymore. Just will also add, the weight on the M should be turned 90 degrees to make getting at those wheel bolts easier. Not a big deal, just my two cents.
