Re: Can't decide if I should restore H with wheel weights?
Posted by Brendon-KS on March 02, 2011 at 16:59:46 from (63.245.190.37):
In Reply to: Can't decide if I should restore H with wheel weights? posted by Yooper Farmall on March 02, 2011 at 13:25:20:
Like a number of other folks said, I like the look of my 350 better after installing a single set of weights. 300 lbs doesn't do a lot for traction, but since I could get them fairly cheap I tossed a pair on anyway. Of course, looks are completely subjective so you really can't go wrong either way.
Just a thought on the snowblower: you might want to consider the reverse speed of the H before investing in one. Might be a little too fast for heavy snow, especially at the engine speed needed for efficient operation of the blower.
