Re: Grinding the Gears
Posted by old on March 02, 2011 at 17:11:15 from (4.245.8.43):
In Reply to: Grinding the Gears posted by Enar on March 02, 2011 at 13:03:57:
Very common with any tractor. You need to push the clutch down count to 50 then shift it into gear. If the transmission has UTF in it and cold out it is even worse but if 90W and cold count to 25. Or yes as the others have said pilot bearing problem is clutch adjustment
