Re: Screwed up...Disassembling a Char-lynn TG
Posted by GordoSD on March 03, 2011 at 07:51:04 from (216.106.248.156):
In Reply to: Screwed up...Disassembling a Char-lynn TG posted by PaddyO on March 02, 2011 at 20:40:50:
I am laughing. Because you are now asking for advice on what to do because you didn't follow the advice you asked for and received earlier. Clear?
Did you find the square seals or use O rings?
If you have the old seals they may help you assemble the unit by looking at the pinch/wear marks on them.
Gordo
