Re: Farmall 560 with yellow block, carb 534932R91
Posted by bc on March 03, 2011 at 08:26:45 from (71.158.219.176):
In Reply to: Farmall 560 with yellow block, carb 534932R91 posted by David L. Bowers on March 02, 2011 at 05:43:09:
David, how many turns to you have the run jet needle turned out? Should be at least 5 for full flow but try a couple more and then pull the throttle wide open.
The way I see it is that if you have a problem in the carb, it will stall and die after you try pulling the throttle wide open once or after a number of tries. However if you can rev the engine up and down without problem until your 40 minutes or so is passed, then you have a fuel tank/line issue restricting flow. Sometimes floaters in tank will do that.
Let us know.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
