Re: Can't decide if I should restore H with wheel weights?
Posted by charles todd on March 03, 2011 at 16:25:51 from (155.130.107.42):
In Reply to: Can't decide if I should restore H with wheel weights? posted by Yooper Farmall on March 02, 2011 at 13:25:20:
At least one set. Its only 300 lbs and completes the look. I'd use the split weights if you can find them. I have 1 set on my 504 and have another set that needs to be installed. I'd like 3 or more for my FEL. By the way Faster346, nice tractors!
CT
