Re: Phil Red Help with H
Posted by The Red on July 18, 2000 at 14:13:39 from (12.75.221.108):
In Reply to: Phil Red Help with H posted by Kurt on July 18, 2000 at 13:55:56:
Kurt pull the distributor cap, dust cap and rotor and crank the engine with the coil switch on. You should see a spark at the points. If not, then check the other small post on the coil and see if you have current running from the coil to the distributor side post. If not, then your coil has probably gone bad. Make sure your points are closing. If the rotor shaft is wobbling, set the points a tad tighter at .017. If you have spark at the points, then carefully inspect the distributor cap and the rotor.
Post A Followup
: Re: Re: Phil Red Help with H
