Re: Farmall Av
Posted by CNKS on March 03, 2011 at 18:52:21 from (216.144.104.128):
In Reply to: Farmall Av posted by Chris corbin on March 03, 2011 at 18:35:16:
AV has 36 inch rear tires and extensions for the larger tires on the front. A has 24 inch rears. AV cultivators are either manual lift or can have an exhaust lift, a large cylinder usually mounted on the left side of the grill. A and AV do not have a front rockshaft, Super A and AV do because they have hydraulics, the pump is mounted to the engine below the distributer, the reservoir is under the gas tank as with your C. Rockshaft is similar or identical to the one on your C.
