Re: 1586
Posted by Janicholson on March 03, 2011 at 19:29:38 from (67.72.98.45):
In Reply to: 1586 posted by Toby Oats on March 03, 2011 at 14:40:42:
There is nothing dangerous about them. Remove the oil plug gently and catch the first drips in a tin can. If no coolant it is a good sign. It should have a water treatment system to reduce corrosion cavitation issues but it is not a deal breaker. Check all fluids and try to charge the batteries. purge new diesel into the replaced filters, if it will turn over, that is great. If it runs it is worth 50% more than if it does not. If the tires are usable and hold air that is probably 1500 to 2000 right there you will not need to spend. Others should chime in, do not drag it down the road, it will not start by pulling it. The hydraulics must be operational to put power through the TA. Jim
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
