Re: Farmall 656 motor issues
Posted by Janicholson on March 03, 2011 at 19:57:04 from (64.61.211.19):
In Reply to: Farmall 656 motor issues posted by andy stockmaster on March 03, 2011 at 18:36:34:
Leaking exhaust at the manifold is a clear indication that the intake and exhaust need to come off. Probable intake leak as well as exhaust. Remove the carb and attachments (take pictures to remember the way it was). then remove the manifolds as a unit. Have the castings checked for internal and external leaks. (between the manifolds is a heat box that can leak exhaust into the intake) Have the mating flanges that bolt to the block surfaced (with it together) such that flat bright shiny metal is now interfacing with a new gasket on a well cleaned (shiny) head mating surface. Use new studs if at all possible, and new nuts for sure. use a torque wrench to reassemble the casting to head. If it still runs poorly we will help from a position of good intake and exhaust. Jim
