Re: 1206 HELP!!!! ONE MORE TIME!!!
Posted by bermuda ken on March 04, 2011 at 05:45:27 from (71.98.29.41):
In Reply to: 1206 HELP!!!! ONE MORE TIME!!! posted by LarryT on March 04, 2011 at 00:22:17:
The cylinder on the RH side is the spring assisted transmission brake linkage. It's an aftermarket item from Hi-Cap. I had one on my 1206 and didn't notice where it made much of a difference in effort needed to depress the pedal.
The clutch itself does not have an "assist" unless one from a 66 series was added to it. IF it was, there would be a large cylinder located midway in the linkage from the clutch pedal to the bellcrank.
My guess on why your pedal is hard to depress is that a Heavy Duty PPA is installed in the tractor. The springs on a HD PPA are much stronger than a stock PPA. This setup virtually eliminates any clutch slippage. The drawback is that the pedal press much harder.
To fix this you can replace the HD PPA with a lighter one OR buy a 2-stick MACK truck and drive it on mountain roads or in a busy city (to build up leg strength), or sell the tractor.
