Getting the manifold off is no problem normally as they use plated cap screws to hold it on. The problem comes in if you want to do it right , that is take the manifold apart to clean and repair the heat riser. Also, note, two different types of gaskets were used. IH went to steel raised beads gasket with composite on both sides of intake sections. That made a good sealing gasket but requires proper tightening procedure with manifold loosly bolted together to properly align itself onto head. Other gasket that most suppliers use is same thickness all the way.I'm not sure if CASEIH still uses embossed composite or not but I actually have a head gasket set laying out at the shop I am working in so will know when I go back out there Monday, weather permitting.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too.
... [Read Article]
Latest Ad:
[More Ads]
