Re: Replacing bolster bushings on H
Posted by Janicholson on March 05, 2011 at 17:06:18 from (67.72.98.47):
In Reply to: Replacing bolster bushings on H posted by BruceS. on March 05, 2011 at 16:38:46:
I believe it is flush with the bottom. Be sure the thrust bearing below it is not in contact with it.
Also you can look at the wear on the shaft to be sure the bushing is where it was in its former location. Jim
