I'd protest you if I saw it. There are a lot of rules for "real" antique pulling. If you are just pulling at fairs and festivals anything goes. Cheat your RPMs as much as you can. You can go 10%ish no problem bc IH did it right from the factory on power units.
You might as well not worry about more hp bc most Farmalls run out of traction before hp if they are on the low end of their weight classes. ie It takes 7500 lb class or more to stall out my SMTA. Anything lighter and I don't have enough traction to stall the engine.
MANY H's had the distillate setup. If you have that put regular gas parts on/in it and you will pick up quite a few hp. If you still want to play with your carb send it to Matt Gall at Motec Engineering in Tipton, IN. He can open up the venturi and thus shoot some more fuel in the motor. It is worth it.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
