Re: Replacing bolster bushings on H
Posted by loren in wi on March 05, 2011 at 19:18:51 from (69.179.16.37):
In Reply to: Replacing bolster bushings on H posted by BruceS. on March 05, 2011 at 16:38:46:
when you take it out keep it in the same way it came out so you can compare it to the new one. You need to line up the grease hole in the bushing. I always take out the grease zert and use a long skrewdriver so I know it is in far enough. This is the correct way to fix most of the steering wobble problems in a front end. I also apply a new layer of grease everywhere when I put them together.
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
