The pully may be held on by the same bolts that mount the fan -- hope I'm not confusing Case and IH here. In any case if the radiator is removed you should first be able to remove all the boldts except the one behind the pully. Then gradually back out the last bolt with an open end wrench as you pull the pump away from the block. John
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
