Re: 1952 SC and outer axle seals
Posted by CNKS on March 06, 2011 at 09:05:13 from (216.144.104.128):
In Reply to: 1952 SC and outer axle seals posted by 62champ on March 06, 2011 at 08:36:59:
There is not supposed to be oil in the axle housing. The inner seal keeps that out, the outer bearing/seal is lubricated by grease. You should be able to remove the seals without removing the axle and housing. You need the seal and a felt washer, available from CaseIH or any place that handles seals. However if there is oil in the housing, your inner seals are shot too. This means you have to remove the housing and replace large gasket and inner seal.
