Re: 1951 farmall H
Posted by The Red on July 19, 2000 at 02:04:52 from (12.75.196.180):
In Reply to: 1951 farmall H posted by george pa. on July 18, 2000 at 15:44:33:
George that should not be a problem. Someone else asked that same question a couple of years ago and I don't recall the answer. The parts ending in D sometimes have different letters after the D for the same part.
Post A Followup
: Re: Re: 1951 farmall H
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
