Re: Re: Re: Re: Re: Red Hot Light Switch
Posted by The Red. WHOA! on July 19, 2000 at 03:00:38 from (12.75.196.225):
In Reply to: Re: Re: Re: Re: Red Hot Light Switch posted by Mike Honour on July 18, 2000 at 09:40:43:
Mike you DO NOT ground the ammeter. The line from the battery, via the starter switch, goes on the right post with the ammeter facing down. The line from the bat. terminal on the alternator goes on the left post along with the coil line and the short line to the light switch assembly.
DO NOT hook anything to the ballast resistor at the bottom of the light switch assembly. Leave it alone.
Post A Followup
: Re: Re: Re: Re: Re: Re: Red Hot Light Switch
