Back to square one
Posted by riverbend on March 06, 2011 at 12:36:24 from (74.46.188.21):
In Reply to: Re: troubleshooting H lift -all posted by pete 23 on March 06, 2011 at 07:57:26:
Well, the control rod does latch back and for a few cycles the pressure relief valve did trip the lever back to neutral, but now it is not going back. It does not make any difference if the bucket is full or not.
Also when I push the rod ahead to lower the bucket the rod will pop back and the bucket stops. This seems worse at higher rpm.
Any ideas about what to look for when I take it apart again would be much appreciated. This time I'll take the pump off the back plate and have a look at all the pins, balls, springs, etc.
Greg
