If the reverse gear is not on its shifter fork, the shifter will act pretty normal in its movement, but if put into any gear, it will be in two gears at once. Reverse, and what ever gear is selected. If the tip is worn, but the rails are put in alignment, and the forks (3 of them) are all on there gears, it will shift properly as long as the H plus one pattern is followed nice and square. This means moving the lever straight forward and back when selecting a gear and straight sideways when moving to left and right. If there is a bent fork, (possible, but do not worry about it yet) that would also allow faulty action. Jim
Today's Featured Article - Field Modifications (Sins of the Farmer) - by Staff. Picture a new Chevrolet driving down the street without it's grill, right fender and trunk lid. Imagine a crude hole made in the hood to accommodate a new taller air cleaner, the fender wells cut away to make way for larger tires, and half of a sliding glass door used to replace the windshield. Top that off with an old set of '36 Ford headlight shells bolted to the hood. Pretty unlikely for a car... but for a tractor, this is pretty normal. It seems that more often than not they a
... [Read Article]
Latest Ad:
[More Ads]
