Re: Super A questions
Posted by med in ohio on March 06, 2011 at 17:19:25 from (208.93.186.70):
In Reply to: Super A questions posted by Questadg on March 06, 2011 at 17:03:49:
The pump ran a lift located between the battery box and the engine. This had an arm on each side of the tractor. On the right side to run a mower deck lift, dozer blade, or cultivators. The left side had a pipe that ran to the back to run the lift arm on the back of the tractor. They go for $2500.00 here in Ohio.
