Re: Head gasket issue
Posted by Owen Aaland on March 06, 2011 at 18:08:41 from (207.13.114.198):
In Reply to: Head gasket issue posted by Eric Uhl on March 02, 2011 at 13:28:04:
The heads on those bolts are 1/2 inch, double square, female.
You can find female sockets without too much trouble but I have never found a source for the male driver. What I did is take a short 1/2" drive extension and grind the end flat so that it fit into the bolt head farther so that it would not twist off all the ball retainer. If you are careful you can remove and install them without too much damage.
