Re: normal operating temperature for a H
Posted by Janicholson on March 06, 2011 at 19:52:00 from (67.72.98.45):
In Reply to: normal operating temperature for a H posted by pintobill on March 06, 2011 at 19:41:21:
If it is a pressurized system with a 7 or 7-1/2 pound cap, it can use a 180 degree stat. It has a pretty large bypass around the thermostat, and might never get that warm unless on tillage equipment, or a feed mill, pulling 20+ hp for an hour or so. They need to run hotter when operating on distillate (if that model) so they used shutters on the radiator, and high heat manifolds to vaporize the fuel. Almost all spark ignition engines engines run more efficiently at 200 degrees than they do at 160. Jim
