If it is only leaking water out to the exterior, and no oil is appearing with it, I would drain the system down to lower than the leak, clean it good, and use a hacksaw blade to recess the gasket a tiny bit (1/16") then fill the location with wind shield adhesive (urethane) and let it cure with a lamp heating it for 2 days. That material is way sticky and should seal it up. (cheap and worth a try) Jim
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
